1999 Ford f350 headlight question - Ford Powerstroke Diesel Forum
Old 01-07-2011, 12:09 PM
My truck is a 1999 F350 4x4 SRW PS 6spd. It has the factory headlights in it, I have seen where people have put newer style headlights in that year and it makes them look alot better. I want factory ford headlights, which 1 could I use that would be an exact fit? I think the 02 or 03 years look good! Thnakns in advance for the help!! I just need newer looking headlights!!! Thanks in advance
Old 01-07-2011, 01:26 PM
check out e-bay. Are you stuck on factory ford parts? I have aftermarket lights in mine, it's pictured in my sig. Mine had the same style lights your '99 would have, and replceing them with the 05-07 ones was easy enough. It did require cutting the hedder panel (a fiberglass peice that bolts to the core support, that the lights mount to) but it wasn't too bad, and removeing the old lights, to me, almost required removal of the hedder panel anyway. Cutting it, test fitting the lights, and re-installing it and the lights was only complicated by the brush guard on the truck that I was too lazy to take off for this project.
As for a bolt-in option, the lights for the '02-04 trucks would bolt in with out any cutting.
If you go with the '05-07 lights, get the GOS Racing headlight harness, it uses the factory wiring to control 2 new relays fed directly from the battery. Very good system, easy to install.
Old 01-07-2011, 01:30 PM
It is easy to install the 05-07 headlights!!
Old 01-11-2011, 04:23 PM
i put the 02-04 oem headlights on mine, and bought aftermarket clear markers off of ebay. i really like the look without having to cutor replace the header panel. these are the marker lights that i got... i was worried about the orange lines, but they are just reflections from the amber reflector. FORD F F250 EXCURSION CLEAR CHROME CORNER SIGNAL LIGHTS - eBay (item 330515604663 end time Feb-03-11 17:57:27 PST)
