Steering Gearbox...
Ok so i have a early 99 f-250 7.3 4x4. Im looking into doing a gear box. This is my only truck so i need everything and anything i need to get it done the first time.
Also How many Splines does it have 32 or 36? I have looked everywhere with no luck Thanks Jeff |
well i found out there is no way to see what splines u got without looking
I had to take my pitman arm off first to count the splins. Might as well that the hole box off so you can get your core return
pre march of '99 all trucks are 32 spline after are 36, I've done my gearbox twice.
Thanks Jeff |
i didnt have to since my shaft broke. but when i put it back on i bolted the box in (not loose) then put it on
My early 99 F350 CC wandered all over the highway. Jody of DP Tuner suggested a redhead steering gear. I ordered one and that took care of my wandering problems. The red head steering gear gas bearing instead of bushing. Easy way to count the splines is take some white marking paint put a dab on one of the larger splines and have someone you trust turn the steering wheel as you count the splines as they turn the wheel.
you don't have to howeveer you do need a special puller to remove the pitman arm from the gearbox.
