Shuts down,wont start. cools off then runs again - Ford Powerstroke Diesel Forum
Old 09-14-2010, 10:38 AM
99 7.3L built in 98
I have fault codes of
p0230 fuelpump primary cicut fault
p0460 fuel level sens ckt fault
p1662 idm en ckt fault
p0344 cam pos ckt intermitant
p0340 cam pos ckt fault
p0470 exhaust pressure ckt fault
p1210 inj cntl pres above expected
p1211 inj pres above/below desired
Replaced the cam sensor about 100 miles ago. this has cured the complaint for this unit before.
Any suggestions?
Old 09-22-2010, 04:25 PM
did you replace it with the black cps from intl.? i hear anything else is total **** and could quit after 100 miles anyways. did you clear the codes and then check?
Old 11-18-2010, 09:39 PM
sounds like what's happenin is ur fuel pump is getting hot and shuting off you may need a new pump
