X rated leaf springs - Ford Powerstroke Diesel Forum
Old 08-26-2010, 11:43 AM
Hey I have an e99 f250 and was wondering if I do the x rated leaf spring upgrade will I need to do anything else. From what I have read this should lift the front end up about level with the back on an e99 since we have the bigger rear blocks but since it is lifting it that much will I need an adj track bar or anything?
Thanks
Old 08-26-2010, 12:08 PM
Feedback Score: 5 reviews
It will lift the front 1.5-2" and if your axle is centered now it will shift 1/2-3/4" We have 2 types of adj bars..DOM steel and Billet Aluminum. Check your shocks to make sure that you have enough travel left. PM me if I can help.
Cary
Old 08-26-2010, 02:07 PM
I am going to be replacing the shocks as well so is there something I should look for in the shocks that I am going to buy. And you are saying I will need the adj bar right?
Old 08-26-2010, 02:17 PM
Well I sell and recomened Bilsteins and adj track bars and can get you the correct ones for your X code swap.
I like things perfect, I don't like axles offset, running doglegged and side loading the spring and shackle bushings so IMO its required. Some will disagree and say none of that matters..only you can decide whats important to you.
Old 09-04-2010, 02:42 PM
where are you getting the x code springs ford? if so do you have the part # I want to do the same thing but am not sure were to get the springs
Old 09-05-2010, 06:21 AM
X — 2C34-5310-AFA, 6,000 lb. 2C3Z5310AF, Local Ford dealer.
Old 09-23-2010, 07:13 PM
so I am going to go with the Rancho rs9000xl's but my question is with the bigger block in the back of the e99 and with my x rated leaf springs that are going in the front do i go with the stock height ones of do I need to go with the 2.5 in lift ones?
