idleing an a/c
well in my e99 goin down the road the a/c is fine blowin cold but as soon as i start to slow down at a light it starts blowin hot air, really really hor air. no leaks feron is good. im lost any help??
maybe we need more info. it gets hot when you idle down, but gets cold again when you give it gas?
i did a quick word search of the forum for "compressor" and there's lots out on the boards. some guys are shimming, or removing a shim on the a/c compressor, and some guys are just refilling and pressurizing the system. sounds like they are having same problems you are, and fixing it. HELP!!!! A/C Clutch Turns Off below 1500 RPM's randomly Air Conditioner there's just a couple links. Last edited by samiam; 08-07-2010 at 08:18 AM. |
When the engine is up to temp and you shut the engine off does the fan clutch keep turning? If it does then its bad. Your not moving enough air through the condenser at idle. When your up to speed you force air thru. Replace the fan clutch and you will probably be OK.
thanks guys i pulled out the washers an shimmed the clutch an its workin like a champ now!!!!! thanks again
you might clean your condensor with some air or water hose at low pressure it made a difference on my 01 v10
