E99 boost questions
so the last couple times ive pulled codes on my truck ive gotten a P1247 low boost, and a P1249 wastgate code. i took it to a diesel tech to see whats goin on. he said it was nothing to worry about. so i installed a boost guage the other day and only getting 15psi. then 16psi with the little red line unplugged from wastgate.
i know the early 99s have different turbos etc. but shouldnt i be making at least 18psi? i heard the EBPV can cause a low boost condition like this so i cleaned the tube and noticed the little diaphram in the sensor was gone. is this the issue? also notice it takes a while to warm up enough to have power. im only getting 13mpg lately too. used to get 17 whats going on?
stock tuning i was getting about 18 psi of boost, with my DP tuner i get 28 psi on 120 race.
ok so there is a definate issue with mine only getting 15psi
any ideas? |
i have gotten up to 25 ibs of boost and thrown a overboost code.
yea but your running a resistor that will give more fuel and increase boost im talkin stock
stock i hit 21 max.
ok well i just checked all the IC boots and tightened em all down. throughin a 5.6k resistor and unplugged the wastegate, just to see how much boost i can make
Check your up pipes for soot, this would indicate exhaust leaks which will do what your truck is doing lately. Also, the EBPV can get stuck. Mine did and I just deleted the damn thing.
no up pipe leaks that i could see. how exactly did you delete the EBPV? im leaning more towards that because it takes forever to warm up even at 60*
i hit 22psi with the 5.6k resistor and the wastegate unplugged, so maybe it was just the IC boots were loose |
I hit 30-32 psi w/ a fooler on a tune.
Stock w/ just fooler I can hit 23 if I try |
