D66 turbo?
I was wondering if the d66 turbo can be used with stock injectors and fuel system? I have currently intake, exhaust, and a crappy bullydog chip which im going to change to a dp chip i think.
ya it will work with stock sticks and fuel system and is supposed to be good for stage 2's as well
The d66 turbo worth doing with stock injectors and fuel system??
from what I understand yes it will, especially if your running good tune
a lot of good word on this turbo..it was a new turbo when i made the swap so i didnt use it,,if i was to do it again id get the D66..good from stock to 450 HP
who sells the d66 turbo thanks
Beans Diesel
Beans Diesel Performance |
Mine has been good to me so far, no surge and she will lay you back in the seat.
With stock turbo I was running 32 psi, the D-66 runs around 26 psi but has way more push. I waited until my stock one grenaded before shelling out for the D-66, it’s a lot of money to spend on something that is still working. |
What about a d66 with the 1.15 exhaust housing and stock injectors? Or the super 66 with the
1.15 housing and the van exhauxt wheel? How much lag is that going to add? I'm assuming it won't be too bad and still pretty driveable. |
The D66 doesn't have a wastegate correct? Since my stock turbo DOES have a wastegate would it be best just to pinch the hose off if i went with the D66?
Thanks. |
