suspension question? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-09-2010, 05:51 PM Thread Starter
the guy i bought my 99 f350 from said it has a 4in lift on it but i don't think so maybe an old wore out leveling kit it front... so how can i tell what it has on it. I'm running 35 on it right know but they rub pretty good when doing hard left turns.
my next question: on the rear the spings dont have those uper overload spings or the pads that they would hit on the frame i noticed them on a lot of other 350 and 250 trucks and was wondering whats the deference.
thanks for your help
Joel
99 F350 Crew Cab Long bed / banks stinger kit
dzydvl is offline
post #2 of 7 Old 01-10-2010, 04:10 AM
Ron's power stroke's Avatar
how thick is the spring pac front and rear ??
on the rear some trucks (not all) have over load springs..mine does..there will be a bump stop on the fraim rail and a single leaf above the stock leaf pac...when 1500 lb is added to the rear of the truck the single leaf should be hitting the bump stop...that will help hold the weight added to the truck and help keep it from sagging rather then the stock springs doing it all..
Early 99 7.3 F350 auto,TN T-4 mount with a s467 thanks to unlimited diesel..shimmed 910's, DI push rod's, new alliant 315/200 hybrids, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
88 F250 7.3 IDI plow truck - bone stock
Ron's power stroke is offline
post #3 of 7 Old 01-10-2010, 04:22 PM Thread Starter
front pack= 3
rear pack= 4+1 flat overload on the bottom
dzydvl is offline
post #4 of 7 Old 01-10-2010, 08:16 PM Thread Starter
help
dzydvl is offline
post #5 of 7 Old 01-11-2010, 01:28 AM
same spring count i got..the rear in mine has a 3 inch block with the spring also...unless them springs have an arch to them you dont have a lift....
post #6 of 7 Old 01-11-2010, 09:30 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Some one added a add-a-leaf to your front and has saged, you can add the spacer and overload to your rears but you will need the frame stops.
CT Performance, Inc. is offline
post #7 of 7 Old 01-11-2010, 08:15 PM Thread Starter
ok i got a 3.5in block in the rear looks like a factory block got some handle lookin thing stickin out on the in side
the spring in the rear looks like this
top spring #1 has the eyes on the end obveusly
spring #2 a little shorter square ends
spring #3 shorter still w/square ends
spring #4 shorter still w/round ends and a little more black is this a add a leaf
spring #5 short stout flat overload leaf
i think i want to put i want to put a 4in lift on it but i need to know with out a doubt what i got i tried taking it by the 4wheel parts place in Fresno, that guy started out real sure then muttered and studdered and i realized this guy had no idea what it had on it. i'm back at work now in san jose is there someone around here that could give me a definitive answer. or is this a stock pack?
dzydvl is offline
