I want heat!!!
Still have the problem with my heater. Blower motor is not blowing so I thought it might be bad. Checked the voltage and there was none. Is there a relay for this because I checked all of the fuses and none were blown.
Please help as we cant use the car right now with the snow
Well I would grab a multi meter and start checking at the switch. See if it is even putting power out to the blower motor.
sounds like its your blower motor resistor it has four wires and its to the right of blower motor my quit working and thats what it was
its one of the two above things. Although when the resistor fails the low position on the fan switch generally still works
Thanks guys. I will go check the resistor. Anyone have a wiring diagram for the heater/ac system to aid in tracing wire's?
I bet resistor, had that go on my f150 already this year and it was crazy rusty so i am willing to be the 13 dollar part went.
Anyone know if the one off of my OBS will work. The blower moters had the same plug.
The f150 has two different kinds so I dont really know. Check napaonline.com and look at the pictures. Its really easy to get to and if you unplug it from the resistor i think it defaults to high speed.
Thanks for the link.
