How do you locate PCM by code? - Ford Powerstroke Diesel Forum
Old 12-02-2009, 05:52 PM
When I go to Car-part.com to check the junk yards for a PCM these are my code options... nothing with pmt2 in it? I searched for a 2002 7.3L Engine computer thanks for any clarification.
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, MT, low emis, ID 2C3F-GC
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, MT, low emis, ID 2C3F-GD
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, MT, std emis (Fed), ID 2C3F-BC
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, MT, std emis (Fed), ID 2C3F-BD
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, MT, std emis (Fed), ID 2C3F-BE
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, low emis, ID 2C3F-HC
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, low emis, ID 2C3F-HD
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, low emis, ID 2U7A-DSA
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, std emis (Fed), ID 2C3F-DC
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, std emis (Fed), ID 2C3F-DD
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, std emis (Fed), ID 2C3F-DE
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, std emis (Fed), ID 2C3F-DF
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, std emis (Fed), ID 2C3F-LC
Elec Cont Unit (ECU), (L. firewall), 8-445 (7.3L, diesel), eng cont, AT, std emis (Fed), ID 2C3F-LD
Old 12-03-2009, 01:13 PM
Feedback Score: 5 reviews
They need to look at the PCM itself..a sticker is on them.
Old 12-03-2009, 02:06 PM
Well then how are some of these guys finding the pmt1 & 2's on car-part.com?
Old 12-03-2009, 05:00 PM
PMT1 or 2
You need to search PMT1 or PMT2 and there should b a bunch of forums on that. Click on the one that says WTB: PMT1 or PMT2 and read those questions and someone already made it easy, they have a PMT2 highlighted in red and if u keep readin it says the one above that one is a PMT1
Old 12-07-2009, 07:13 AM
02 PCM's wont work, you need to look for an 01. Then use this list to find your PMT1 or 2.
