Hey guys, have the early '99. Recently replaced my fuel filter and was trying to clean the bottom of the fuel bowl out and broke the fuel bowl heater element off of the plate down in there.
I've searched and have gotten mixed answers as to whether or not you have to replace the entire fuel bowl ($600) or if you can just replace the heater element. Someone said they got one from International for $42??? It wasn't clear whether they were referring to the early '99 heater element or the late '99 heater element, though.
So what's the deal? Can I replace the heater element at the bottom of the fuel bowl? Or do I have to replace the entire fuel bowl?
You can replace the element, but you don't need it. I would just unplug it on the outside of the fuel bowl, tape the plug up and be done with it. But if you really want a new heater, look here and he has an affordable replacement.
I've already unplugged it. It was 32 degrees today and had a little bit of a fit starting after sitting for a couple days, but not much at all. I'm just worried about later this winter when it gets down into the single digits with ice and snow and everything.
It makes me think that it hasn't worked the entire time I've had the truck. It's always been a pain in the *** to start when it's super cold outside. It probably needs glow plugs and glow plug relay too, though.
The new style will work and it'll be easy to replace. If you know what you're doing it should be a ten minute job give or take a cup of coffee at 12 degrees outside.
Go to dieselorings.com and look at the writeup he has there on how to rebuild the fuel bowl. You'll see what it takes to do it. Basically, drain the bowl, remove the filter, remove the wire connected to the heater in the bowl, remove the two screws holding the center post and heater in, pull out the old and put in the new heater, connect the wire to the heater, retighten the mounting screws that hold the post and heater in, put the filter back in and or put the lid back on, close up the drain valve, cycle the key a couple of times to refill the fuel bowl with fuel and then you should be good to go. Caution: That center black post has got little parts in there under spring pressure so try to keep it all together inside of the post as you remove it or you'll be picking up little pieces here and there and wondering how it all goes back together (dieselorings.com has a good exploded view picture that shows the correct order of the parts if things do pop out all over). In fact, if I remember correctly, if you're careful, the post can be held in so as to stay in the bowl while you slip heater in and out of the bowl over the top of the post. Hope that makes sense.
ALso, I don't think that the fuel heater would really effect so much the starting of the motor as it helps the running of the motor(???). If you're having troubles getting started then you're probably needing to look at the glow plug relay and glow plugs first.
I plan on replacing the glow plug relay as well to start with. I found a Stancor replacement online for $40 and will be ordering that pretty soon. the previous owner kept all records of maintenance and repairs and the glow plugs and GPR have never been replaced (truck has 235,000 miles).
FWIW, we've had highs in the single digits for the last 4-5 days here. My truck hasn't been started since Thursday, and even though I plugged it into my timer this morning it still took a while to start, but it did start. I think you'll be fine.
Yea, we've had highs in the low 20's recently and it's started without much hesitation at all. It maybe cranks for 2-4 seconds and fires. Tonight will be the real test (suppose to be single digits and snow a few inches).
The fuel bowl heater is not so much as for starting as keeping a good fuel flow and not jelling up while running down the road. If it shorts out, it kills the computer (on the same fuse) and here in the MT,you can't run her without it. You can unplug the heater, but with the daily high at zero right now(-8 avg), it just won't start.
Just drain the bowl, two #30 torx, and a spade plug and she's done.
I found it easier to pull the stem in the center when inserting the new heater (just put the stem through when the spade is connected,(otherwise you would really stretch the wire )
I picked mine up for around 34.00 at the local International dealer.
BTW, I drive an E'99, '01, and '03, besides the one in my sig, all strokers.
Good luck
As far as starting, I'm cold blooded, so I leave a cord in the bumper all the time
I had the exact same problem yesterday, but instead of buying a new element, I just soldered the element back onto the plate. Is there anything wrong with this? or should I have just bought a new one?
Also, Losfinch's post says that there are little parts under the black post. When I took mine apart there was only a spring.
The little parts are "inside" of the post...if they're not there someone gutted them out previously (some do that to try and cut down on any restrictions in the fuel path to the injectors). If you're looking for a new fuel bowl heater here's the new improved style for a great price: 1999 FORD F-350 SUPER DUTY Diesel Fuel Heating Element
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
