hard starts - Ford Powerstroke Diesel Forum
Old 11-22-2009, 12:39 PM
BOSS LEVEL
hard starts
so i have been having hard starts more often now. i can let the truck idle for a few mins and shut it off. the next crank takes a few secs longer than normal to fire up. someone told me it could be the ipr going out. b4 i spend $$$ i just want to know if that was the issue or its something else. oil has been changed and is full (with 15qts) and has a new fuel filter. plus the napa air filter isnt dirty...yet. just a grey tint on the white paper.
so what can it be?
Old 11-22-2009, 12:52 PM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
weak hpop maybe
Old 11-22-2009, 12:57 PM
BOSS LEVEL
is there any way to test the engine to get a definate answer?
this only has 125k on the engine
Old 11-23-2009, 05:06 PM
If you don't have access to good scanning tool that can read the pressure for you then you could make an oil pressure reading tool for about $60 at any good hydraulics store. Get one with hose rated to over 3000 lbs working (about 12,000 burst). Or, for a little bit more, there is a guy on ebay that has brand new IPRs for under about $85. Also, check that your ICP is working correctly (see if there is any oil in the top of it).
