Question for techs - Ford Powerstroke Diesel Forum
Old 11-17-2009, 03:41 PM
Question for techs
How can I confirm that my fuel pump is weak and going out? That is what I think is wrong based on how the truck is running but I need to be 100% sure before I buy one.
Old 11-17-2009, 03:43 PM
Maybe flow or pressure test. I know I know, not a tech. But givin it a and just throwin that out there.
Old 11-17-2009, 03:50 PM
is it electric or mechanical?
Old 11-17-2009, 04:34 PM
Well I believe it to be the frame mounted electrical pump. Truck runs like its missing. Fuel pres guage is very jumpy even at idle ad will not go over 40lbs
Old 11-17-2009, 04:41 PM
<<---"Shadow"---
Factory fuel pressure is 58ish if I remember correct. I will see mine drop momentarily to the 40-45 lb range at wot but it quickly comes back up.
Also, where you got fuel pressure gauge tied into?
Old 11-17-2009, 04:47 PM
make sure it has 12 Volts going to it than you can ohm it Im just not sure what fords spec is on those pumps I could look it up on all data tomorow at work if you want
Old 11-18-2009, 03:33 AM
Mine is less then 40lbs at idle. You dont want to know what it is at WOT.
My fuel Gauge is hooked to the port on the back drivers side of the fuel bowl. Thats where ISSPRO's directions had me put it.
I will check that out today.
Old 11-18-2009, 04:06 PM
Bumping this up.
Old 11-19-2009, 03:09 PM
Again with the bump!
Old 11-19-2009, 03:46 PM
Send a message via Skype™ to excursionMark
On 98.5 and newer engines: The newest version of the PowerStroke has an electric fuel supply pump. Pressure readings are taken at the fuel rail plugs at the front of the RH head, the rear of the LH head, and at the fuel pump outlet. The fuel pressure should be over 30 PSI, but anything below 50 PSI will cause an injector knock. If the pressure is low at either head, replace the check valve at that head's fuel rail inlet. If it is low at both heads and the pump outlet, check the pressure regulator at the fuel filter return line for debris or a split o-ring. If the regulator is OK, check for a fuel pump inlet restriction as described above.
got that from PowerStroke diagnosis ... idk if it will help but its someinfo for ya
