Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
  #21 (permalink)
Old 11-07-2009, 06:55 AM
99dieselsmoke 99dieselsmoke is online now
Originally Posted by toddyman88 View Post
On your clunk, does it do it every bump or just occasionaly? Do you feel it in the seat like its under you or really just in the front like you said? Asking beacuse I have a similar issue but mine radiates thru the body on the drivers side driving me crazy. I pulled carpet last weekend and tightened the hell out of all the body and bed bolts to no avail. I will not do it every time maybe one out of 3 bumps....defenatley on the drivers side although the passanger can feel it to. Has done it since I bought it, before lift, balljoints, wheels, tires ect. My mechanic told me the same thing to grease my new balljoints and gave me the zerks. Need to get this clunk/banging taken care of though.
Dont know where to look now.
Try the sway bar bushings and end links. Mine was doing the same thing and i bought new bushings from NAPA for $10 and that cured the loudest clunks in the front end. I need to replace the end links too but they're $60 bucks a piece!!!
  #22 (permalink)
Old 11-07-2009, 07:32 PM
toddyman88 toddyman88 is offline
I have new end links and bushings that came with the longer drops with the Skyjacker lift kit. I then bought Energy Suspension bushings for the sway bar mounts themselves.
I will verify that all that is still tight tommorow but my noise was there even before the lift.
AS far as the computer code goes, I guess the paper tag came off and got lost when I installed the DP tuner inside so I have no numbers to share.
I was wrong on the truck door pillar mfg. date, it is 12-98 not 11-98. Still an early 99 though. The tag on the drivers side valve cover also says mfg. date of 12-98 on the engine too. I did the foil delete on it today. While I had all that apart I snapped a pic of the compressor wheel. Is this a wicked wheel? Still trying to narrow down why my surging is so prevelent.
Thanks.
  #23 (permalink)
Old 11-08-2009, 09:20 AM
wckdpowerstroke wckdpowerstroke is offline
Yeah sounds like our clunks are the same. Not every bump mostly bigger bumps. Can feel it like your saying through the cab. Driven me crazy!
  #24 (permalink)
Old 11-08-2009, 10:00 PM
jesilvas jesilvas is offline
Thanks.
The cut off between early and late is 12-7(or 8)-99.
You had the foil AND I'm pretty sure that's a late compressor wheel. Sorry bud, think you got a late 99.
  #25 (permalink)
Old 11-09-2009, 05:46 AM
Maybe a late 99 engine inside an early 99 suspension. I know its early on that since I did the lift myself w/o issues.
If it is a late 99 engine im ok with that. Now I can ge the ported housing and different wheel and correct this surge issue. Are you sure thats a late wheel?
I removed the foil sat.
Thanks
  #26 (permalink)
Old 11-09-2009, 06:41 AM
Pretty sure. Here's the wicked wheel/early wheel/x wheel.
http://www.dieselsite.com/index.asp?...PROD&ProdID=47
