Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
  #11 (permalink)
Old 11-05-2009, 07:03 PM
toddyman88 toddyman88 is offline
Mfg date 11-98. Starting to wonder if the truck had a later model engine put in it after it was built between this and the major surging issue I have that everyone says it should not do on an early 99. Wonder if there is a tag or something on the engine itself I could refer to?
  #12 (permalink)
Old 11-05-2009, 07:10 PM
jesilvas jesilvas is offline
You can check the engine mfg date and the compressor wheel.
  #13 (permalink)
Old 11-05-2009, 07:16 PM
panheadjay panheadjay is online now
my 99 don't have foil, but has a cat.
  #14 (permalink)
Old 11-05-2009, 07:19 PM
jamstoyz jamstoyz is offline
congrats on the truck and the extra $500 i would talk to one of the vendors on here. i know raul runs a package deal on the basics to get you started and the $500 should take care of that. imo, straight pipe it with no muff. that will save more money than doing a full kit with muffler and it will sound much better. a diy intake will save you also than buying a afe or s&b. i would also check the classifieds on here. you may be able to find a used dp or tw for cheap. make that $500 go far bud. good luck
  #15 (permalink)
Old 11-05-2009, 07:29 PM
Where is the mfg date located and how do I tell the difference in the wheels?
  #16 (permalink)
Old 11-05-2009, 07:33 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Originally Posted by toddyman88 View Post
My early 99 has foil. It did not have a cat.......are you sure yours does??
I ran into a few things out of the gate on my 99 with 148000 on the clock as I began mods. My balljoints (uppers and lowers) were shot. That was expensive to fix. My water-pump was bad as well. Had to have a new torque converter put in. Point is, go over the truck well before decking it out.
The DYI intake should be high on your list. Easy to do, cheap and very effective.
The MBRP 4" turbo back shipped to the door was $300.00. Its quieter than the stock system with no muffler but it flows much better. Dont dog it alot and the egt/s wont hurt you w/o a gague.
Gagues should be next. I like my glow-shift set. They were affordable with a mounting pod off ebay. Some of the guys have had bad luck with them (as I have with much more expensive name brand items on other vehicals) but they have been flawless for me. Everything I needed was included for a great price.
With all that in place your set up for a good set of custom tunes. I love my DP tuner.........better than advertised.
Have funn!
Gordon
Originally Posted by jesilvas View Post
You sure that's an early 99? Cause the earlies didn't have foil if I'm remember right.
To add to the question above, what is your PCM code?
I too have never herd of an early99 with foil except for a truck or two that had their IC pipes replaced for some odd reason.
  #17 (permalink)
Old 11-05-2009, 08:03 PM
I will have to get the exact numbers off from it tommorow, but when I checked all that before contacting DP for my tuning it showed to be for an early 99.
I will get the specifics tomorow and let you know......im curious now myself!
maybe there is something weird going on here.
  #18 (permalink)
Old 11-05-2009, 08:35 PM
Mfg date should be on the driver door support sticker.
You can go to some places like diesel site or just look for the x wheel/wicked wheel and see what it's like. The late 7.3 compressor wheels were different.
  #19 (permalink)
Old 11-06-2009, 10:42 AM
wckdpowerstroke wckdpowerstroke is offline
No foil for me, but yep has a cat.
Well it has an new water pump, new alt, ball joint are all servicable other than the uppers. Runs great! Will need to do the fluids soon. Only thing i really noticed is a clunk in the left front just when hitting bumps. My mechanic buddy told me for the upper ball joints to take the nut off the bottom put a 90* zerk in and grease them and then put the nut back in. Cant leave the zerk in because of the axle rotation.
  #20 (permalink)
Old 11-07-2009, 06:33 AM
On your clunk, does it do it every bump or just occasionaly? Do you feel it in the seat like its under you or really just in the front like you said? Asking beacuse I have a similar issue but mine radiates thru the body on the drivers side driving me crazy. I pulled carpet last weekend and tightened the hell out of all the body and bed bolts to no avail. I will not do it every time maybe one out of 3 bumps....defenatley on the drivers side although the passanger can feel it to. Has done it since I bought it, before lift, balljoints, wheels, tires ect. My mechanic told me the same thing to grease my new balljoints and gave me the zerks. Need to get this clunk/banging taken care of though.
Dont know where to look now.
