ggagues installed but no boost at idle - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-12-2009, 04:22 PM Thread Starter
toddyman88's Avatar
OK, strange question............should I show boost on my gague at idle? How about when in park but reving the engine? Only comming up to about 20 on the gague when I get into it on the road then let off the pedal and it gies back to 0.
I had to use a splicer and extra tubing to hook it up.....no leaks there but would the restriction have anything to do with it? Tee is in the map sensor hose. Maybe a bad gague?
Never had a boost gague before so not sure what to expect.
Thanks
EARLY 1999 F250 7.3 SUPERCAB 4x4 SWB
6" ROUGH COUNTRY LIFT, ALL SPRINGS
RC SINGKE STABILIZER
DUAL SHOCKS UP FRONT
37" TOYO MT'S ON 20" FUEL BOOST WHEELS
RANCH HAND FULL FRONT AND REAR REPLACMENT BUMPERS
4" TURBO BACK MAGNAFLOW SS EXHAUST
DIY INTAKE WITH OILED FILTER
DP-TUNER F-5 CHIP
GLO-SHIFT GAUGES
INTERNATIONAL BADGING
F550 SUPERDUTY BADGING
toddyman88 is offline
post #2 of 19 Old 10-12-2009, 04:28 PM
elm302's Avatar
Feedback Score: 3 reviews
no boost at idle is normal wot boost seems a little low tho what tunes for ur chip do you have
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #3 of 19 Old 10-12-2009, 04:30 PM
<-Day Of Fail now SOLD
POWERED SPARKLESS's Avatar
No your boost wont show at idle or park/nutral no matter how much you rev it. I think for a 7.3 that sounds about normal.
Tyler T
Sold 2 April 2011
To some lucky SOB
2004 6.0 CC FX4 Lariat
It had all the right things missing or added
Originally Posted by DunesRunner08 View Post
IF YOU DO NOT STAND BEHIND OUR TROOPS....FEEL FREE TO STAND IN FRONT OF THEM!!!!!
POWERED SPARKLESS is offline
post #4 of 19 Old 10-12-2009, 04:30 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
You wont see any boost at idle nor will you likely see it reving in neutral. At WOT it should be around 23 - 27ish.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #5 of 19 Old 10-12-2009, 04:34 PM Thread Starter
toddyman88's Avatar
The 20psi was with my 80hp economy dp tune. Did not want to run it in the 120 race or 140 extreme untill I found out if the gague is good or not. So whats the reason the engine builds no boost on park or neutral? Just curious......
BTW....Thanks for all the fast replys....Much appricated.
DP-TUNER F-5 CHIP
GLO-SHIFT GAUGES
post #6 of 19 Old 10-12-2009, 04:40 PM
1995psd's Avatar
its not under load
1995psd is offline
post #7 of 19 Old 10-12-2009, 04:42 PM
Originally Posted by 1995psd View Post
its not under load
Tyler T
Sold 2 April 2011
To some lucky SOB
post #8 of 19 Old 10-12-2009, 04:49 PM
elm302's Avatar
i can build about 5 or psi on my 6.0 if i just punch it in neutral or park i guess casue the vgt turbo
elm302 is offline
post #9 of 19 Old 10-12-2009, 04:50 PM Thread Starter
toddyman88's Avatar
ok....guess it makes sense. Needs the backpressure of the resistance of moving the truck I guess. I will run it in the other tunes tommorow and see what the presure is. Is 20 real low for the economy tune? The truck will MOVE its A.S for sure. Day and night difference over stock. Can hit 80 mph in no time.
DP-TUNER F-5 CHIP
GLO-SHIFT GAUGES
post #10 of 19 Old 10-12-2009, 05:07 PM
I can build boost in my 97 7.3l powerstroke in neutral when step on it 2-5 psi
Powerstroke Cowboy is offline
