Pyro install question - Ford Powerstroke Diesel Forum
Old 09-10-2009, 03:44 PM
Where is the correct place to install the thermocouple for a pyro gauge? Can it be installed after the turbo on the exhaust down pipe?
Old 09-15-2009, 06:35 PM
bump on this one...anybody?
Drivers side exhaust manifold
Old 09-15-2009, 06:48 PM
The pyro on my truck is installed on the exhaust downpipe. I'm looking to upgrade to a 4" turbo back, and the thermocouple is welded in. Do you think I can salvage and re-use it? I'll install it in the correct place this time!
Anybody have some pictures? Is it hard to drill and tap the exhaust manifold?
Old 09-16-2009, 06:17 AM
You should be able to re-use it easily... there is probably a fitting that is threaded into the down pipe that the thermocouple threads into. Remove the thermocouple, remove the fitting, then just drill and tap your manifold or up-pipe. Have you ever used a tap before? It's pretty straightforward, but the two things you need to know are that if the tap is off center in the hole very much it may break off (and they can be a biotch to get out if that happens) and when you are tapping, go in 1 turn then back out 1/2 turn to break the shavings loose so they don't plug the threads on the tap and make it bind or break. Use some sort of cutting fluid, a little bit of motor oil would be fine for this application. Drill your hole pointing straight down, and 95% of the shavings will fall to the ground when you drill and tap... there is no sense in worrying about anything that might be left inside once you are done. Some people like to grease the tap to catch the shavings, I don't think it's necessary or a good idea.
Old 09-16-2009, 07:04 AM
wriott
Guest
Posts: n/a
drivers side manifold, easiest to do it from under the truck, make sure you put it in a spot that you can use the tap handle and not hit anything
Old 09-16-2009, 07:31 AM
Thanks for the posts. Does anybody have a picture so I can have a better idea of what I'm getting into? I've tapped skis before when I was a ski tech, but nothing metal. Is there anything in the manifold to accidentally drill into?
Old 09-16-2009, 07:36 AM
The other side
It is real easy when you get under ther you will see where to put it.
Old 10-18-2009, 04:17 PM
if you want a picture fast just do a google search of F250 gauge install. that was the fastest way for me when i put mine on
Old 10-18-2009, 05:50 PM
I found some great pics and instructions here:
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
