Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 06-17-2009, 05:38 AM
ndennis93 ndennis93 is offline
power assisted brake??? HELP
My buddy has an E350 with a BD programmer. He took off this morning to go to the store and when he got ready to apply the brakes he said he had none.???????? Anyone know what whats going on? He said he heard a loud ticking coming from the driver side engine compartment.
Any suggestions?
Old 06-17-2009, 06:01 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
First check brake fluid. If there is none then refill resevior and bleed brakes. Look for leaks.
If there are no leaks in the system, check for leaks from the hydroboost. If no leaks are found from the hydroboost. Then three things could be the problem.
Either the powersteering pump is failing or the Hydroboost is failing, or it is the brake pedal assembly.
Check the level of the powersteering pump fluid. Does he have good powersteering. If he has good powersteering and the fluid level is correct. Then the only other two things it could be is the Brake Pedal Assembly or the Hydro-Boost itself.
Old 06-17-2009, 06:20 AM
Thanks!
I just spoke with hima again and he said that the pedal was really really hard. And he went through an intersection running 70+mph because he couldn't get it to slow down!!!!
Old 06-17-2009, 06:21 AM
Originally Posted by ndennis93 View Post
Thanks!
That tells me it is either the hydro boost or the master cylinder.
He needs to stop driving the truck. Park the dang thing have it towed home or to a shop.
Old 06-17-2009, 06:42 AM
CHUCK CHUCK is online now
Lifetime member
Vaccum pump?
Old 06-17-2009, 06:48 AM
It happened first thing this morning. He has already contacted the dealer and plans to have it towed there. He's not driving the van.
Old 06-17-2009, 07:55 AM
Originally Posted by CHUCK View Post
Vaccum pump?
The Vaccum Pump has nothing to do with the brake system on our trucks. The power booster for the power brakes receives hydraulic pressure from the powersteering pump.
Another thing it could be though is the ABS control.
Old 06-17-2009, 08:11 AM
Lifetime member
Ahhh...learn something new everyday
Old 06-17-2009, 09:33 AM
dieselcrawler dieselcrawler is online now
Look into the ABS... I have simular problems with my van too... brakes are good, fluids is fine, plenty of power steering, but I feel the ABS 'pulse' at times... winter time when the roads are slick, the ABS is doing something, but what is does is make it more un-safe to drive. I'd like to ditch it all together... but when it acts up, it pushes back on the brake pedal, and as your buddy said, makes the pedal 'hard'.
Old 06-17-2009, 07:45 PM
m-chan68 m-chan68 is offline
Powerstroke Techie
Vaccum pump?
Yes, I would 2nd that. I believe the OP specifically mentioned an E-350 which DOES use a vacuum type brake booster (as opposed to a hydroboost style assist on F-Series and E-450 trucks), that gets its vacuum from an engine driven pump. This is also very consistent with the loud noise heard from the driver side of the engine compartment where the vacuum pump is situated. I know I have replaced more than my fair share of these, on these vans.
