Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 06-10-2009, 09:24 AM
metallitera metallitera is offline
Question 6.0L oil filter location
thanks to search not allowing 3 letter words, i might be digging up an old topic, but i couldnt find the answer.
im not savvy on the 6.0's, and all the ones ive messed with were trucks. well today, was looking at out only ambulance with a 6.0L in it and i couldnt see the oil filter cap on top of the engine. made sure i was looking in the correct spot (about 10:30) in relation to the fuel filter as it is in the expedition and F350 with 6.0s. that spot looks to be open on the E450 ambulance. intercooler and and oil fill tube go right through where i was expecting the oil filter to be.
ahhhhhhh!!!!!!!!!!!
Old 06-10-2009, 09:30 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
ahhhhhhh!!!!!!!!!!!
oil filter is cartridge filter and is located on the drivers side beside the oil pan underneath the vehicle
Old 06-10-2009, 12:14 PM
hmmmmm was wonderin if it was beneath
thanx
Old 06-10-2009, 07:28 PM
elibenson elibenson is offline
There should be a little allen-key style plug in the end of the housing that will let you drain the filter housing and supply lines without making a big mess when you change that filter. If you don't drain the housing, it will spill about a quart or more of oil on you when you unscrew the housing.
