Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 06-08-2009, 06:07 PM
ZYDA ZYDA is offline
How do I know if I am suppose to have an OverDrive
I just bought a used 2000 E350 with a 7.3l engine in it. Am I supposed to have an overdrive button somewhere? The knob on the gear shifter is broken and I didnt think to ask the seller if there was anything besides a knob attached.
I would like to know if all 2000 e350's cvame with overdrive and How would I go about finding out?
Any help will be beneficial... if the OD has no button, does it mean that it is on by default and is functioning and just cannot be switched on or off? How would I know if it is on? I have a gear selector that shows P R N D 2 1...
Old 06-10-2009, 12:29 AM
txevt txevt is offline
Send a message via Yahoo to txevt
the overdrive on/off button is at the end of the gear shift lever.
Old 06-10-2009, 04:25 AM
The knob is broken and there are no wires sticking out from the broken end.
Old 06-10-2009, 07:12 AM
dieselcrawler dieselcrawler is offline
Replaceing the shifter/knob assembly is not diffucult, and the new one will come with the knob, button, wires with clip-in type end... had one replaced in my '94 gasser, I think the parts were less than $60 for shifter, knob, button, etc. Took my buddy the mechanic less than an hour to do... and he's slow.
Old 06-10-2009, 07:35 AM
Ahhh... that is good to know.
I took the beast out and drove around a bit yesterday and found that the vehicle resets the OD to "on" as I was told on another board. The only time I would need a button would be to get the van out of OD which is seldom. I counted the gear changes... the change fron 3rd to 4th came at around 50-55 MPH. I am assuming that the 4th gear is the OD and it is working.
Thanks for sharing know-how and experience...
Old 06-10-2009, 08:13 AM
elibenson elibenson is offline
Sounds like you got it 100%
On a van, you rarely need to take it out of overdrive. Maybe if you live in the mountains, or if you plan on towing with it some..
Old 06-10-2009, 09:00 AM
nccatfan nccatfan is offline
Send a message via AIM to nccatfan
I've had other Fords with automatics that have lights come on in the guage cluster that says "OD off"
Old 06-11-2009, 06:35 AM
I think the old work van I had, a '91 I think, had the button on the shifter, but the light was on the dash...
However, if the button is missing, it can't be turned off, and thus, won't light up...
For the year of van, it's probly on the shifter knob...
I'd agree, towing is the only time I ever use the OD off button...
Old 07-20-2009, 05:32 AM
F350 STROKER F350 STROKER is offline
i have a van and the botton is on the shifter like my truck
