convert POS 5.4 to 7.3 possible? need help!!! - Ford Powerstroke Diesel Forum
Old 06-02-2009, 10:30 AM
Hi I just bought a 1997 E-350 with a 5.4 gas engine in it i only paid $500 for the van the motor is blown and needs to be replaced I would love to put a 7.3 in the van i have one in my f250 and love the motor is it possible and how much work would it be to do
thanks
Ben
Old 06-03-2009, 01:14 AM
Send a message via Yahoo to txevt
5.4L gas to a 7.3L DI turbo
7.3L DI turbo complete from or for an E350 (turbo is different and air intake is smaller than F series
E4OD transmission (if not already in the van)
Flywheel?, gas pedal assembly, radiator, core support, upper/lower/heater hoses, belt, vacuum pump, overflow tank, radiator cap, alternator, batteries group 50 and 65, batteries cables, pcm, idm, wiring harness, exhaust system, driveshaft?, air filter assembly and tubing, engine mounts, various nuts and bolts.
I do not know where the ac compressor and power steering pump is on a 5.4L gas in an E350 and if hoses are the same. Battery bracket for second battery. Dash components, wait to start light?
Engine hoist for the 7.3L. A special bracket made by Rotunda (well when I bought one) and extra person (225lbs or so) to stand on the engine hoist cause it will nose dive with the powerstoke attached. I know.
Old 06-03-2009, 05:21 AM
thanks
Im still looking into costs and all that good stuff Im trying to decide if it is worth it or if i should just repair the engine in the van and sell it and buy one with a 7.3 in it already thanks for the response it was a huge help
Old 06-03-2009, 06:03 AM
repair and sell... buy one already with the diesel... less work, less money. The swap will nickle and dime you to death, and it's still gonna be a transplant with meny possible issues.
Buying one that came factory will make everything fit the way it's suppost to.
