Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 04-07-2009, 02:20 PM
dieselcrawler dieselcrawler is offline
Need van gauge pod
Lookin' to add 3 gauges to my '99 E-350 work van in my sig... don't care for the 'A-piller' pods, block too much sight, it's bad enough with the west coast style mirrors. Lookin' for ideas for in the dash, on top of the dash with a clean look with out exposing wires, etc.
Any ideas? Any one done this? Any pics?
Thanks...
Old 04-20-2009, 06:26 AM
howardtm howardtm is offline
Made mine (for an 03 E550- dash should be the same) holds 4 guages though..EGT, Trans Temp, Boost and Tach. Not real pretty but works just fine. It sits on the dash next to the drivers side "piller" just below eye level so it's always visable. I think I may still have an extra in the garage. I'll try to get you a pic if you think you mighty want it. Let me know with your email addy and I'll get it out to you. Oh..by the way, if you want to hook up a tahk..its real easy(at least on the 03) and you don't need a special tach..any will do.
Old 04-25-2009, 02:27 PM
Hey Howard... thanks for the reply... I'd like to see what you came up with for the gauge pod... and the tach interests me too....
electricwonder at hotmail dot com if you want to throw some pictures my way...
Thanks!
Old 04-25-2009, 02:57 PM
rpm-inc rpm-inc is offline
I just installed a 99 f cluster and now have a factory tach. Here are my gauges. They are 2 5/8 and wish I went with 2 1/16. I may redo it with a 4 gauge a pillar and a steering column mount.
Old 04-25-2009, 03:44 PM
just got back from "on the road". Will try to get some picks of the pod I made for mine and get them out to you. By the way..as for the pillar mounts..unless you can fabricate one yourself, as far as I know, they don't exist for the E series. oh..almost forgot! as for the tach hookup. look closely at the harness that comes from the PCM(engine comp side) and look for a white/pink strip wire that kinda dead ends about 8-10inches or so back into the harness..THATS your handy dandy tach lead..at least on the 03 it is...And you're not too far away either..am in Pittsburgh.
Old 04-25-2009, 03:50 PM
Autometer makes one. Auto Meter
And several people have used truck pillars and did a little filing to fit. I have a steering column mount that will require a little filing but will work fine.
Old 04-25-2009, 04:04 PM
just took a couple of shot..will send them to you in a few.
Old 04-25-2009, 04:39 PM
cherck your email
Old 04-25-2009, 04:41 PM
2005F250 2005F250 is offline
Rmp-inc, By the looks of your sig it sounds like you have a badazz van.
Old 04-26-2009, 11:23 AM
It does okay. I need to update my sig. Now has swamps 300's and I am almost done fabbing a compound setup. Looking for about 585 at the wheels.
