Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 03-03-2009, 05:34 PM
kwiederhold kwiederhold is offline
e450 oil leak 7.3
2000 e450 7.3 oil leak, thought it was passenger side valve cover gasket, changed it and is again leaking, it is wet around the passenger side exhaust manifold just under ther valve cover , driver's side is as dry as brand new, any ideas?
thanks
Old 03-03-2009, 06:07 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Hmm not sure. Is there any oil in the valley of the motor?
Old 03-03-2009, 06:09 PM
nope, no oil there, i was about posivie it was the gasket
Old 03-03-2009, 06:17 PM
How about around the dipstick?
Old 03-03-2009, 06:21 PM
well, actually that is leaking also, but icompletely cleaned the engine, ( lots of brake clean ) after changing the pass.side valve gasket, and it is still leaking from the pass side valve cover area. i know about the o-ring behind dipstick tube in oilpan ( whos idea was that ? )
Old 03-03-2009, 06:29 PM
You can thank the engineers who don't have to work on them for that!Is the valve cover making a good seal?
Old 03-03-2009, 06:34 PM
re
i think so, it seems like it may be coming from the front of the head and just running across the bottom of the valve cover
Old 03-03-2009, 06:41 PM
Hmm maybe leaking around the crank position sensor?
Old 03-03-2009, 06:43 PM
would they end up by valve cover though?
Old 03-03-2009, 06:51 PM
My guess is no, but anything is possible. Take a look its in the 10 oclock postion in front on the passenger side you will see the wiring plug. Its behind the front crankshaft pully. See if its wet from oil
