Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 02-25-2009, 01:20 PM
jag02920 jag02920 is offline
E350 wont run. 7.3L Diesel
Half hour after filling truck with fuel, truck suddenly lost all power and acted as if it was not getting any diesel. I was able to drive it home but it struggled to get any speed. Once I got up over about 35 mph the truck ran better. Since then the truck has been parked and wont start (over a year). I took the sending unit out of the tank thinking it was bad fuel and put the sending unit in a bucket of clean fuel. Still not running. When the truck does start it sounds like the exhaust is restricted. I have been manually moving the exhaust valve thinking that it is bad but it still wont start. Pulled off the SBP sensor and ran a wire down tube (as far as I could), still no change. can anyone suggest anything or should I just sell it as is, not running...
Old 03-28-2009, 03:22 PM
sjermike sjermike is offline
Send a message via AIM to sjermike Send a message via Yahoo to sjermike
check your fuel filter, or replace it. the first sensor i would suspect would be the cps
