Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 02-24-2009, 11:02 PM
Pengyou Pengyou is offline
Another engine option?
I am going to look at a 92 econoline 350 with a 7.3L nonturbo in it. It is an entended van.
Are there other engine options for this - specifically a turocharged option? Another Ford engine? a 4BT or a6BT? I am mostly interested in better mpg but also want durability.
Old 02-24-2009, 11:22 PM
Hoganshero Hoganshero is offline
ford didn't put a turbo on the 7.3 till 94. As far as other options ummm you could always do a motor swap. Also i know banks makes a kit to turbo charge the idi motors dont know if other do as well
Old 02-25-2009, 08:38 AM
Thanks! will a turbo from a later model 7.3 fit on a non-turbo model? What are the easiest engine swaps to do for the econoline?
Old 02-25-2009, 07:15 PM
umm your best bet would be to post that question in the 7.3 section about turbo options and choices those guys could rattler off 100s of options im sure. And as far as the engine swap i would imagine a cummins 5.9 would be the easiest since its one of the smallest engines. I dont think a 4BT would be big enough. Some one with more knowledge on the econlines should be about to help you out a bit more
