09 E-350 6.0 Ambulance dual alternator testing - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-19-2014, 07:19 PM Thread Starter
I have a 2009 6.0 E-350 that is giving me an average voltage of 13.87 at 16,00rpm and another truck same everything is giving me 14.17 volts. The truck with the weaker voltage sometimes throws codes for injector circuit low voltage for all cylinders. I'm guessing the lower voltage is messing with the FICM. How can I narrow down which alternator is getting weak/ and or not working? should I disconnect one alternator at a time and test with a multimeter? What should my readout be because the sizes of the alternators are different? Thanks
Pswagg64 is offline
post #2 of 2 Old 03-23-2014, 05:38 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
The upper alternator is a 140 amp and the lower is a 120 amp if they are both factory and not aftermarket add-ons from the body builders.
Both alternators should provide maximum amperage at 2000 RPM. The internal voltage regulators determine how much output they provide based on the charge of the batteries.
Now honestly the charging system may not be seeing a fault. I know for a fact all ambulances are not created equal and their electronics vary. The workshop manual says if there is no battery light and no charging system DTCs then everything is working normally. 13.8v is not out of the realm of normal for a 6.0 even at 1600 RPMs. Hell sometimes the electronic readout for the system voltage is wrong. Make sure your testing it with an actual voltmeter. Also make sure your batteries are up to snuff. Weak batteries will obviously pull more of a load out of the system as they try and recover.
If you want you could try disconnecting each alt and testing the output with an amp clamp. I do not believe both run full capacity at all times, they only charge as much as needed. Running as many accessories as possible during testing will give the best results as the alts will be working at full or near full capacities.
Also one more thing, you need a FICM. All injector low circuit codes are a good indication of a failing DC/DC converter inside the FICM.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
Tags
6.0 advice , ambulance , dual alternator
