Help with 98 7.3 Conversion Van E350 info - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-24-2013, 07:15 AM Thread Starter
Matt-X's Avatar
I'm looking at a 98 7.3 1-ton conversion van and I'm having trouble finding any info on them? Looks like they are sometimes referred to as an e99 but cannot confirm this
Anyone know any pros/cons/issues/specs on these? I want to be able to haul the whole family and drag my camper. It's a 36' 9500# tag-along. My 01 flatbed CC 350 does the job now but is tight with 2 car seats and 3 dogs
Any help or insight will be appreciated!
Matt-X is offline
post #2 of 3 Old 11-25-2013, 12:52 PM
Not sure if your van is an e99 or not but im sure a ford dealer can tell you once provided with the info. Either way, the 7.3 is a monster and should tow that trailer w/o problems. I would get an EGT gauge and scan gauge II to monitor engine vitals.
I would always carry a CPS with you (cam position sensor), check the air filters, coolant level and sca content and transmission. I believe this model will have the e40D transmission so I would check over it extensively as they and the 4r100 (found in 99-03 models) trannies are know for failing. If it has been rebuilt, you may not have any worries. Good Luck
2000 E350 Cargo PSD; 3.55
- Tow mirrors
- ScanGauge II w/ X-Gauges
- DP Tuner F5 80econ, 80tow, high idle
- Boost/Pyro Gauges
- soon to be 4x4 w/ NV271
djbonsu is offline
post #3 of 3 Old 11-25-2013, 02:49 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
door sticker will tell you when it was built.
im sure its a e99 with the 4r100.
and the vans dont have intercoolers either.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
