Belt tensioner location on 6.0 van? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-08-2013, 01:02 PM Thread Starter
DieselDweller's Avatar
I am still harboring the fantasy that I will not have to pull the shroud and fan in order to remove the alternator. I can see the little tensioner lock from underneath, but I can't figure out where to pull on the belt in order to engage it.
Also cannot see which pulley is the tensioner without pulling the fan and shroud.
Tips appreciated...
06 E-350 with 6.0
Quigley 4x4
Sportsmobile
Swamps hot FICM
IDP Street Tune
Updated FPR spring
About to have a new oil cooler and Sinister upgraded EGR Cooler - remind me to get back to work and quit surfing the web!
DieselDweller is offline
post #2 of 2 Old 01-24-2014, 03:43 PM
I just did my alt in my 06 6.0 E350
if you are staring at the front of the engine it is at about 730 oclock. I was able to get a breaker bar on the tensioner but couldnt get the "swing" i needed without loosening up the shroud. I did not remove the fan, just the 4 bolts that hold the shroud to the engine.
Take the time to spin all idler pulleys, etc to check for a bad bearing on one.
Replace the fuel filter while you're there, unless it is brand new.
mobetta is offline
