2004 E series radiator replacement advice? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-20-2013, 03:32 PM Thread Starter
My '04 E450 6.0 developed a very small crack in the radiator top just inside the upper radiator hose. It's barely visible, just a hair line, but it was slightly hissing and seeping after returning home from a trip to Mid Ohio Sports Car Course a couple of weekends ago. If it were my old chasis I'd probably rough it up and JB Weld it, haha, but I think a replacement is in order on this one. I searched and didn't find any specific threads to radiator replacement on the E Series. Any words of wisdom or suggestions of links with some good instructions? Still running the gold coolant too so this seems like a good time to flush it out with distilled and replace it with ELC after the new radiator is installed.
Thanks for any input or suggestions.
PS. I also posted this in the general forum because of the higher traffic...
BobH99 is offline
post #2 of 4 Old 12-09-2014, 04:27 AM
Not a lot of help I see......e series doesn't seem to be the "go to " answer chain hun.....I am dealing with a crack down lower and from looking at the location....I may just set fire to it!.........hehehehehehe
dr2casto is offline
post #3 of 4 Old 12-11-2014, 10:53 AM
I just replaced the radiator for my van but it has the 7.3. It took about 25 min to install plus another hour or so to flush the system. It was as easy as disconnecting the air box, hoses, and pulling back the shroud, that's it.
2001 Ford E350 7.3 Extended Cargo Van
BTS Transmission, PHP Minotaur package, 4" exhaust/downpipe, Honey Badger jr., FRX, HPX, AIH delete, Fuel bowl mod, Hypermax Boost/Pyro gauge, 4.10 rear.
Xphobe is offline
post #4 of 4 Old 12-11-2014, 09:39 PM
Quoted: 37 Post(s)
No experience with it but this replacement is all aluminum and appears to be plug and play for an E350 with a 6.0. https://shop.performanceradiator.com...roduct_id=5296
I might be wrong but I believe the Bulletproof diesel radiator is the same thing, just rebadged. It's also quite a bit cheaper. No surprise there.
05 E350 4x4 6.0 99k: DC Power XP250A, Dieselsite coolant filter, ELC coolant, IPR GEN2 EGR delete, KCturbo Stage 1.5, updated turbo drain tube/oil feed line/STC fitting/OEM oil cooler, cat delete, high-flow muffler, SCT Tuner with IDP Xstreet tune, PHP Atlas 40 FICM tune, Blue Spring, billet fuel filter cap, BPD water pump, Scanguage II, AutoMeter fuel pressure and pyro gages, Tru-Cool Max 40,000 GVW transmission cooler
6.0vanman is offline
