Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
  #21 (permalink)
Old 12-24-2008, 12:22 PM
beisel1111 beisel1111 is offline
I just bought a 95 with a 7.3. 80k miles on it for only a thousand bucks. Didn't need it but couldn't pass it up at that price.
  #22 (permalink)
Old 01-15-2009, 05:11 PM
devo devo is offline
Mine is in the sig. It has 386,000 on it. I've replaced: water pump, alternator, front wheel bearings, rear axle seals, steering linkage. It still has the original turbo and exhaust on it! It's not babied at all. I hammer on it every day. If I take off the ladders I can get 19 mpg.
  #23 (permalink)
Old 02-23-2009, 10:13 AM
dieselcrawler dieselcrawler is offline
This is my first post in the van section... even tho it was my first PSD! I've had my '99 E350 in my sig for almost 3 years, it's a work truck with an 11' Stahl utilty box on the back... great to work out of, but sure is a turd compaired to my SuperDuty. Have to let it warm up 5 to 10 minutes or it won't get it's self out of the drive way, worse when it's really cold out... I'd like to straight pipe it, remove the cat, and DP-Tuner... and figure out a better intake/air filter.
  #24 (permalink)
Old 03-03-2009, 12:46 AM
ozyonezzy ozyonezzy is offline
I just got installed the evolution system and it is incredible the power difference on just the lowest setting . One customer towing a trailer recorded a 4 mpg gain on a trip from canada to arizona. The best part is no turbo lag off the line , just a little on the peddle and the van lurrches forward.Plus you get gauge read outs and trouble codes. Will pay for it self in a year if i was on deisel but i run on veggie
  #25 (permalink)
Old 04-06-2009, 08:13 PM
powerhog powerhog is offline
1997 E-350 superduty 7.3L extra long... i think this site is great. i am new to it still but like what i see so far. hope more things get posted...
  #26 (permalink)
Old 04-07-2009, 11:58 PM
Ears93 Ears93 is offline
97 E350 EXTENDED 7.3L Anyone install a larger downpipe on one of these? I know you have to "modify" the firewall on the trucks. Is there more clearance in the van or do I need to modify the doghouse?
  #27 (permalink)
Old 04-08-2009, 05:40 AM
elibenson elibenson is offline
There is a ton of room there to put a new down pipe in. You can use a truck down pipe if you have a welder. You need to cut it in the middle and take out a few inches and weld it back together. Or use a splicing clamp maybe. I tried a factory down pipe off my brother's 2003 7.3l on a van, and the dimensions are the same as far as the bends and an angles and such. The only difference is that it hung down below the frame. So it would have to be shortened.
Go and look under your van with the dog house in place and see how much space you have down there around the down pipe. It's actually quite a bit of room. You can easily go 1" bigger than stock and clear everything, I think.
  #28 (permalink)
Old 04-08-2009, 06:26 AM
rpm-inc rpm-inc is offline
A few goodies on mine.
  #29 (permalink)
Old 07-11-2009, 03:52 PM
High Mileage Jim High Mileage Jim is offline
Satisfied owner of a 2003, 7.3, E350 with 745,000 miles. Completely original engine, trans and rear end. I've replaced a couple of Alternators, 4 sets of tires, 3 sets of brakes, 4 vacuum pumps, 3 sets of U-joints, 1 belt, 1 water pump, 3 batteries, the heater core and rebuilt front suspension once.
Working on 1,000,000 miles. 2 more years.
Forgot to mention, a lot of oil changes (Valvoline PB2000 only), filters, light bulbs and wiper blades. Engine, Trans and rear end are treated every 4 oil change with MotorKote. Look it up, it's an unbelievable hyper lubricant.
  #30 (permalink)
Old 07-11-2009, 05:00 PM
That's incredible. What do you do to put that many miles on it? What's your oil change interval?
