Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 07-24-2006, 12:04 PM
mrgregory mrgregory is offline
overdrive?
2002 E350 7.3 Towing 12 K Do I need to run with overdrive off? With overdrive on, over 70 miles trans temp runs between 170 and 190. Is this ok? Thanks
Old 07-24-2006, 12:19 PM
Banshee34 Banshee34 is offline
If you are running totally flat ground I feel it's ok to run in Overdrive, but if there are any hills, etc... Overdrive should be off!!
Old 07-24-2006, 04:27 PM
Log Dog Log Dog is offline
That is one hard lesson learned
Old 07-24-2006, 04:43 PM
trans slipping
2002 4r100 pulling 12k trailer, trans seems to be slipping when it kicks out of overdrive or when I turn overdrive off. Not sure because I do not have a tach but It makes louder than normal spinning sound. didnt start until about 4 hours into a trip. trans temp never went over 190. I could power though it sometimes.
trans fluid is clean and doesnt have burnt smell. almost sounds as though it is going down to 2nd gear. Help?
Old 07-24-2006, 04:51 PM
Ok trans is slipping with overdrive off. what know?
Old 07-24-2006, 06:26 PM
slipping
Old 07-24-2006, 06:30 PM
mschn99 mschn99 is offline
PM harald@BD......he is pretty knoledgable about these trannies.......
Old 07-25-2006, 12:40 AM
Diesel Nut Diesel Nut is offline
Send a message via AIM to Diesel Nut
Sounds like maybe its coming out of lockup?
Harald should jump in here soon. He's the wizard!
Old 07-25-2006, 03:11 AM
dickbaker dickbaker is offline
Send a message via Yahoo to dickbaker
overdrive won't go off
3 weeks ago I bought a '02 f-250, my first diesel. Took me about a week to get used to the glowplugs before starting up. Just noticed a couple days ago the overdrive button to click off overdrive doesn't work, everything seems fine tho', no problems or noises. But I wonder if there is a fuse for the overdrive button that blew. Looked in the manual but can't find a fuse listed for that. Anyone have any ideas. Thanx in advance.
Old 07-25-2006, 04:55 AM
Crosshead Crosshead is offline
Have mine in the Tranny shop right now for the same reason,Tech found a snap ring that holds what I would call a servo plate for the over-drive was off.My truck wasn't pulling at the time it started the problem,just running it hard.Acted like it came out of over-drive ,but when i slowed down ,saw that beepbthe O.D. was still off.I tried the button and the tranny shifted out of O.D.The tech told me that this plate/servo I call it, will reposition its self until under a load agian.I tried like hell to get to do it again,but couldn't.Truck only has 88,000 on it,but I wanted to know what was up and to upgrade-T.C. valve body and eletronics.I went ahead with a Banks 6 gun and I'm adding a tran-temp gage also.Good luck with yours, mine should be out Wednesday.Mike
