Front wheel berring lock nut torq ft/lbs? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-18-2012, 07:48 AM Thread Starter
dieselcrawler's Avatar
Quoted: 23 Post(s)
I had to replace the front wheel berring on the pass side of my work van yesterday... what I don't know is how tight the castle nut should be when it's re-installed... I snugged it down, but I'm guessing there should be some pre-load on the berrings, I just don't know how much. What's the ft/lbs it calls for?
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #2 of 4 Old 10-25-2012, 04:36 AM
jamiesgarage's Avatar
99 E350 per ford technical resource center
Install the spindle nut.
NOTE: The brake disc and hub should be rotated while adjusting wheel bearing end play.
Tighten the spindle nut. 30ft/lbs
Loosen the spindle nut two turns.
Tighten the spindle nut while rotating the brake disc counterclockwise. 17-24 ft/lbs
Loosen the spindle nut. 175 degrees
Tighten the spindle nut. 17in/lbs
Install the following components:
Install the retainer nut.
Install a new cotter pin.
Install the hub grease cap.
Install the disc brake caliper anchor plate. For additional information, refer to Section 206-03.
Install the wheel and tire assembly. For additional information, refer to Section 204-04.
or just torque it to the original 30 ft/pounds while rotating
then back it off, spin it once
then snug it hand tight and reinstall your retainer (thats what id do)
Jamie's Garage med/heavy truck service, morrisville VT
08 Nissan Titan
91 F250 460ci
79 Camaro Z28
68 Jeep M715
jamiesgarage is offline
post #3 of 4 Old 10-26-2012, 06:45 AM Thread Starter
Quoted: 23 Post(s)
Hey man... thanks for the info, exactly what I was looking for. And nice to know that's basicly what I did... tighten it up while turning it, back it off, snug it up, new cotter pin, and put it back together... drives so much nicer now! There were chunks missing from the rollers of the berrings I took out, I don't know how it was even still rolling, let alone driveable. Rumble, and slightly sloppy sterring was the only symtoms.
Greg
Semper Paratus
post #4 of 4 Old 10-26-2012, 07:00 AM
i had a hub let go in my old silverado one morning on my way to work. started grinding something aweful, when i jacked it up the whole wheel went "thunk" to the side. im pretty sure the caliper was the only thing that kept me from rollin in on 3 wheels. i wish everyone still used actual wheel bearings, makes things alot simpler and more cost effective.
08 Nissan Titan
91 F250 460ci
79 Camaro Z28
68 Jeep M715
