Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 10-08-2007, 07:41 PM
kink1950 kink1950 is offline
2002 won't start when sitting on an incline
I have an 2002 E350 7.3 and have had it not start 4 times when sitting on a slight incline overnite. It will run for 15 seconds and then die and not restart. Towed it to level ground and had to start with starting fluid. Starts fine when it is on level ground. Oil level is just slightly low.
Old 10-08-2007, 07:43 PM
2005F250 2005F250 is offline
Top off the oil and see if it helps.
Old 10-08-2007, 07:46 PM
I got it started this morning but it is an intermitten problem that has happened over a year period. The first two times I had it towed and they never found a problem, but it brings up a 1212 code.
Old 10-08-2007, 07:52 PM
Here's the code description. P1212 Injector Control Pressure Not Detected During Crank
