Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 10-04-2007, 07:36 AM
aea59 aea59 is offline
Loss of Power - Please help
We have a 2000 Ford Econoline E350. The truck started lacking power in the driving mode. The transmission control light was blinking on the shifter. Tested the turbo for turbo pressure. It said it had very low pressure on a hard pull, approx 3-4 lbs. Changed the turbo seals and whe adapter. Still had same issue. Ran the codes with adtc. It said that the epc module was malfunctioning. Put a new epc module in, changed trans. filter and oil, including the torque converter oil. Replaced with ford motorcraft oil. still had a loss of power and light still blinking. Had the codes read again and this time it said that there was a short circuit in the wiring harness to the transmission. Pulled the wiring harness and bench tested the harness with an ohm's tester and the back half of the harness checked out good. Put harness back in. Still had the same problem. Messed around with the up half of harness and vacume hoses. Ready to give up and I went to move the truck and the light was not blinking and the truck ran like it should. Drove truck 3 days without any problems. The following day went to use truck and the light started blinking and a loss of power again. Checked the wire at the map sensor cm, maf sensor and the vacume hoses. went and started the truck and it ran fine. The following morining the light was back on and again a loss of power. Checked everything and could not find the problem. Ran codes and code came back again.
I have no idea what direction to go.
Old 10-04-2007, 07:43 AM
jfines@cox.net jfines@cox.net is offline
Sounds like your on the right track.
I would check all the wiring again. This time note any thing that you do. It could be a faulty connection going into a sensor. or a short midway.
Also, make sure the connections going into your PCM and IDM are tight and look good.
Old 10-04-2007, 04:15 PM
Action Rick Action Rick is offline
What were the codes?.....
Old 10-04-2007, 04:21 PM
mschn99 mschn99 is offline
Banished
sounds like you got a tranny problem causing hte motor to get bogged down....quit chasing your tail and follow the codes to what the problem is...
Old 10-04-2007, 04:44 PM
Marty Marty is offline
International Threat
Send a message via AIM to Marty
I'd bet you're getting the 0720 code when you get it tested.
