Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > E-Series Van Discussion
Old 09-11-2007, 05:36 PM
goldstr1 goldstr1 is offline
Unhappy how to test fuel pump on 1997 E350??
Is there away to tast the fuel pump on a 97 E350 A wire diagram, would help. Is the puymp in the tank or outside the tank the truck was built oct.1997
Old 09-11-2007, 05:43 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
I might be wrong but I think 97 was a mechanical fuel pump? Someone will correct me if im wrong. You could pull the filter to the fuel bowl drain it and crank the engine over to see if it fills the fuel filter bowl. Also if its an electrical pump do the same thing but cycle the key and see if it fills the filter bowl.
Old 09-17-2007, 04:04 AM
Thanks for all the help! This is a great forum
I got it running this weekend, runs better than ever
Old 09-17-2007, 01:57 PM
Good news! So what was your fix?
