What kind of hitch is this? - Ford Powerstroke Diesel Forum
Old 05-25-2011, 03:24 PM
Does anyone have any information on this hitch? I am in the process of buying this van and it has this crazy hitch on it. I want to tow my boat (about 4,000 #'s total). Is it safe to do so with this hitch? Does anyone have information on this setup? Can I lock it out, or would I want to?
Thanks,
Brearly Mason
Old 05-25-2011, 03:38 PM
Powered by Deez Nuts
that is a swing hitch.
like this
Towing World Official Website
now imo i would remove it and put a traditional one on. but thats me.
Old 05-25-2011, 03:45 PM
Really? This hitch doesn't "swing" like the link you posted, but rotates from side to side. It is very, very heavy duty and is bolted on with 16 bolts through the frame. It looks like it is marked for 10,000 lbs, but its not clear. Why would someone use this style hitch over a regular setup?
Old 05-25-2011, 03:47 PM
well that one does swing left to right due to the bent I beam under the bumper.
Probably to make sharper turns?
Old 05-25-2011, 03:57 PM
The Silent Service
If it rotates, most likely its for manuverability at slow speeds, and initial hook up. Highly doubt it would handle 10K (look at the safety chain loops), even if it is marked for it. Occasionally you see hitches fabricated on, that may have decent ratings when they leave the factory. Regardless of what and who made it, once you get the van, get rid of the blasted thing. Even with only a 4K load, its better to play it safe.
Old 05-26-2011, 09:00 AM
I finally found it...
PullRite has a SAFER, STRONGER, BETTER designed hitch for you
Thanks!
