oil leak - Ford Powerstroke Diesel Forum
Old 04-28-2011, 03:25 PM
oil leak
Working on a friends 04 e450 6.0 psd. He had coolant puking out so we started with a oil cooler rebuild and an egr cooler. Put hack together and had a large oil leak running down both sides of the motor. Appeared to be coming from oil cooler. So we noticed that coolant was still puking I pulled engine and found a bad head gasket and a leaking glowplug sleeve. Fixed that up and stuck engine back in with a new oil cooler and housing. Properly torqued everything and fired it up no more coolant pressure hut still had the oil leak. It appears to be coming from the front of the oil cooler cover on passanger side. Any common leak points here? Its leaking out fast
Tags
oil leak
