New to forum and towing with a 7.3 E350 - Ford Powerstroke Diesel Forum
Old 09-26-2010, 12:32 PM
Hello all. ive had this van about a year now. ive towed with it a few times already. ive made a few standard changes to it and now have some questions on improving the towing of this van. i realize the 7.3 e350 is detuned. thats ok as im not looking for a tractor pull sled truck
I just wanted to see if these temps were normal before i hook up another trailer. i tow a flat car trailer and offroad truck total weight about 10k im guessing.
Without my trailer and with my new gauges and pod im getting a paltry 5psi of boost when getting on the interstate and going up the merge ramp. seem quite low but i dont know what im supposed to get. this van is tired and was used as a magazine delivery truck before i bought it. it has 500k miles on it. so 5psi boost may be all to expect out of a none wastegated no IC cooled truck with that many miles.
Second EGT's are around 800 and dont top that. i can quickly cool it down by letting off the trottle. this is not towing and that number may go through the roof...I dpnt know yet and am scared to find out. Would removing muffler and cat lower EGT's? or is the best way 4" or 5" exhaust? the 4-5" exhaust for our vans seems overly expensive. i called around and it was always 500$ more for the vans than the trucks because "sales of the van exhaust are lower so the price is higher" is the reason im given.
Lastly. my transmission temp is 140 on the interstate never goes above that. thats thanks to the 6.0 trans cooler. i highly recomend that mod to those that have not done it. it was hard shoehorning the 6.0 large cooler into the van but it will fix with some determination.
One other thing. Whistle. I like the turbo whistle. i dont have that much. i guess my turbo is worn. is that little black box on the engine on passenger side hindering the turbo in any way?
I dont really want to put a ton of money in this truck. I also dont really want to chip it either since it has so many miles on it in the first place. if those numbers above are normal i guess i can live with it.
thanks for any and all advice from you pros here
Old 10-03-2010, 09:27 PM
boost gauge could be off? my 2000 7.3 van lower speed hard on the gas boost has hit 19psi up around 65 mph maybe 11-12 psi hard throttle, I don't know why that is. boost guage hard pegged on the 0 pin? takes full throttle before it lifts off?
I payed like $330 shipped for my diamond eye 4" turbo back straight pipe. The only other exhaust supplier for the van I know of is Jones exhaust.
From what I've found on EGT Max sustained temp is 1250 degrees. 800 sounds ok to me you gotta make heat to move the truck.
I believe that box is the injector module.
Old 10-04-2010, 07:01 AM
Thank you for the pointers. the boost gauge is not off. i hooked up an air compressor to it and blew in the line at 20 psi and it read 20 psi. turbo must be worn i took off everything off the top of the motor to get to the turbo. there is no in and out play on the turbo fins. however there is slight side to side play on the turbo. im getting 5psi when on it hard. 1-2psi boost when slightly on accelerator.
If i replace the turbo im going to go with a 4" or 5" downpipe off a truck and just cut it off and reweld it to shorten it up.
Old 10-04-2010, 09:09 AM
downpipe
the 2 manufacturers I referred to before both offer van 4" downpipes that will fit, and line up with your existing, you'll just have to taper it down to 3 1/2 to max the exhaust tube underneath. If it's like mine the factory exhaust will neck down to 3 to go through the muffler. I took my muffler off, with it blowing through the turbo it's not that loud unless you are on it, then it does get pretty loud, and is loud around 65 mph. The truck downpipe and the van downpipe should be the same money, so I would just buy the van one.
