trans question - Ford Powerstroke Diesel Forum
Old 05-24-2010, 12:50 PM
trans question
i have a 1996 e350 powerstroke 7.3l e4od transmission is acting up when am going down the road the shift from 1st to 2nd (automatic transmission) there is a hard shift/cluck. and when slowing down there is about the same thing any ideas od light does not blink. have changed trans fluid and filter .any ideas
Old 05-27-2010, 03:40 AM
Universal joints in the drive shaft all good and tight? Do you hear this clunk going from drive to reverse, say, while in a parking lot? Can you tell the location of the clunk, front/rear, left/right?
Old 05-27-2010, 09:27 AM
trans question
well the trans fluid it burnt after getting it changed a few weeks ago so that is that .but my other question is a 1994 ford e350 trans not a powerstroke able to be put in the 1996 ford e350 powerstroke cub van thanks for your help
Old 05-29-2010, 12:21 AM
I think the bell housing bolt patern is diffrent from gas trans to diesel trans... you'd have to check that for sure.
