drw to srw info needed - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-03-2014, 02:16 AM Thread Starter
Hey fellas Im.picking up a 99.5 cc f350 4x4 7.3 dually.Im getting a great deal on it & it was a service truck & well maintained but I have no need for the extra wheels Im not gonna be doing much towing&I already have a lifted dodge & any truck I drive gets lifted & I dont wanna pay for the extra tires espically since the smallest I will roll is 35s.
So I would like to know the easiest way to switch from drw to srw?Ill be honest I know.nada about pulling these hubs or spacers etc but I do know from what I read that theres a way to do without swapping out the axle.And Im not worried about the bed as I do bodywork for a living.So what if anything do I need to do to the front wheels & what to do to the reAr without pulling axles.If anybody has a write up Id appreciate it.Thanks in advance
Please excuse any typos or terseness: this email was sent from my mobile and I have clumsy fingers.
cutthroatxxx is offline
post #2 of 22 Old 08-03-2014, 06:50 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Front is easy, unbolt the dually spacers and put a standard wheel on. Done.
Rear, could be as simple as pulling off the duals and putting a standard wheel on, but its my understanding that the rear track width is wider on the dually rears than srw trucks, so the rear tires would stick out more than the front once you remove the dually fenders and the bedside is normal.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #3 of 22 Old 08-03-2014, 11:25 AM Thread Starter
well that sounds easy enough I dont mind the tires sticking out more I could probablly run 12.50s in.bk&13.50s infront 2 make.it look right
post #4 of 22 Old 08-03-2014, 11:34 AM
Quoted: 27 Post(s)
I would just get the right axle for the rear if that's the case, running wider tires in the front will look funny when you go to rotate tires lol
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #5 of 22 Old 08-03-2014, 11:50 AM Thread Starter
really dont wanna swap incase I go back 2 drw,I dont care about what others think plus Im gonna put a tire chanver in my shop
post #6 of 22 Old 08-03-2014, 01:16 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
All you have to do is measure the rear from hub to hub and measure the front hub to hub. Subtract the front from the rear and divide by 2 and buy that size spacer for the front.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #7 of 22 Old 08-05-2014, 11:01 AM
countryraised's Avatar
why would you want spacers on front? most trucks the front is already wider than the rear. most likely hos front and rear would track right over eachother now, just might stick out to the edge of the bed in the rear, could be fixed with fender flares.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
post #8 of 22 Old 08-05-2014, 11:13 AM
F3502wd's Avatar
Feedback Score: 3 reviews
Is that the same for 2wd?
F3502wd is offline
post #9 of 22 Old 08-05-2014, 11:58 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
yes, from what I've seen they too also have the same spacer
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #10 of 22 Old 08-05-2014, 12:04 PM
F3502wd's Avatar
I know they have the spacer but I remember reading that it's not as easy as removing the spacer....on a 2wd
F3502wd is offline
