Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 01-18-2009, 09:30 PM
Iowa_Stroke Iowa_Stroke is offline
Dually Tire Rotation
Hello,
Well I to have fallen prey to the fat bottom girl. I just got my first dually. How do you rotate the tires for wear? I hate to sound like a noob but can the front and rear rims be flipped outer rear to front front to outer rear? It seems that the inner rear have the least wear of the six? Is this normal? Do I need to remount the tires each time I rotate? Also interval are you rotating at? I know a lot of questions but I want to get it right!
Thanks
Old 01-18-2009, 09:40 PM
TurboSevenThree TurboSevenThree is offline
I miss the 90's. =[
Well you can't just rotate 'em. The tires have to be swapped from rims. Unless you have 6 of the same rims. I don't remember how they rotate, i'll find it.
Old 01-18-2009, 09:46 PM
Goose350 Goose350 is offline
Obamacare..
TANK'S Library
Scroll down, You will see it.
Old 01-18-2009, 09:47 PM
I miss the 90's. =[
Yeah it's
Outside rears go to inside rears
inside rears goes to fronts
fronts go to outside rears.
Old 01-18-2009, 10:05 PM
Thanks for the link. So every 5000 miles I have to have all 6 tires rotated and dismounted and remounted? What is that costing guys?
Old 01-18-2009, 10:07 PM
I miss the 90's. =[
Like $70 if I'm not mistaken. I sure don't do 'em every 5k though............. they're wearing fine.
Old 01-18-2009, 10:09 PM
Tacomarunner Tacomarunner is offline
Why would you have to dismount the tires from rims? Is the inside rear not an aluminum rim? Wouldn't it be cheaper in the long run to just get aluminum rims?
Old 01-18-2009, 10:12 PM
I miss the 90's. =[
Yeah normally outsides and fronts are aluminum or whatever and insides are steel.
Old 01-18-2009, 10:22 PM
That is what I have front and rear outside are aluminum and insides are steel so are the rear outside rims and fronts the same? I guess that then I will only have to switch 4 tires if that is the case. How often are guys rotating the tires for even wear?
Old 01-20-2009, 02:56 PM
BlackPearl03 BlackPearl03 is offline
its free at discount tire.
