Front alignment - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-02-2014, 08:30 AM Thread Starter
Front alignment
I took my truck to get a alignment and guy calls me and says they need to replace the tie rods first. They would not do the alignment until then. They told me how much to replace the tie rods and then do the alignment. It was like 800. I did not do it so no alignment. How long do you guys see the tie rods last? 2005 f350 drw about 94000 miles. What the best way to check them?
race735 is offline
post #2 of 9 Old 07-02-2014, 08:38 AM
ZMANN's Avatar
Quoted: 1566 Post(s)
800 is steep compared to what is involved if they are just doing the 2 tie rod ends IMO
94,000 isn't crazy early
it all depends on what kind of life the truck lead
best to have someone turn the wheel back and forth a little and watch for excessive movement you can also try to twist it and see if it feels sloppy at the joints
We Miss you Ronnie
ZMANN is offline
post #3 of 9 Old 07-02-2014, 08:47 AM Thread Starter
I am going to pick it up and try checking them. Doing long trip this weekend and was hopping to just get an alignment and move on. My real question is can it wait.
race735 is offline
post #4 of 9 Old 07-02-2014, 11:52 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Check for slop, if none it can wait, but also best to get a second opinion as well, good luck and safe travels
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 9 Old 07-02-2014, 01:34 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
yes it can wait unless is super loose then might be time, if just a little then it'll just wear the tires faster but it be fine
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #6 of 9 Old 07-02-2014, 03:31 PM Thread Starter
Thanks for the replies. I check it and its only a little on the left side. I have no idea what they guy was talking about. But i did get to learn something new about the truck today.
race735 is offline
post #7 of 9 Old 07-02-2014, 03:38 PM
ZMANN's Avatar
you should have asked them to show you what they were talking about when it was in their shop I think they should have no problem with that request
We Miss you Ronnie
ZMANN is offline
post #8 of 9 Old 08-06-2014, 08:30 PM
SAILOR97's Avatar
I just replaced mine OEM FORD parts for 197 bucks and then took it in for alignment. There very easy to change out. I found them on ebay and like I said genuine OEM Ford parts. I know this may be a lil late though
Edge CTS Insight w/turbo timer, EGT probe, Fuel pres., SCT X4, DC Power 185 amp alt., NUC Motorsports deluxe oil bypass, Rotella 5W-40 W/Rev-X, Sinister Coolant Filtration, ZEREX CAT ELC-1, Dual Exhaust Stacks.
SAILOR97 is offline
post #9 of 9 Old 08-06-2014, 10:22 PM
Field Truck's Avatar
OEM tie rod ends are an easy swap. Mark the old and new and you should be close to alignment specs prior to the swap. And, not knowing the truck history, you might have other worn steering/suspension parts as well.
For sure find a shop that specializes in allignment work. Too much at risk to go with any other.
Field Truck is offline
