2wd dually leveling kit HELP! - Ford Powerstroke Diesel Forum
post #1 of 39 Old 06-30-2014, 01:17 PM Thread Starter
F3502wd's Avatar
Feedback Score: 3 reviews
I bought the steel spacers from summit racing (2") and took it to the dealership to install. They stated that they put the biggest cam in there and the camber is sooo out of whack that if you turn the truck it hits the brake caliper. Is there something that Im missing?
F3502wd is offline
post #2 of 39 Old 06-30-2014, 02:03 PM Thread Starter
F3502wd's Avatar
F3502wd is offline
post #3 of 39 Old 07-01-2014, 03:26 AM Thread Starter
F3502wd's Avatar
common no one? Now they are telling me to use the pro comp one which sits on top of the spring oppose to the bottom?
F3502wd is offline
post #4 of 39 Old 07-01-2014, 04:58 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
That ships from my hometown, who is saying to use the procomp camber? Do they offer a better one?
What is the caliper hitting?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 39 Old 07-01-2014, 05:06 AM Thread Starter
F3502wd's Avatar
The dealer said that they used the biggest cam that they have and still cant get it aligned. When they turn the tire it hits the caliper. I called tirecountry which is known for lifts and they said to use the procomp spacer. But by looking at the pics its the same piece.
F3502wd is offline
post #6 of 39 Old 07-01-2014, 05:10 AM Thread Starter
F3502wd's Avatar
What kills me is that i see threads with 2wd leveled duallys
F3502wd is offline
post #7 of 39 Old 07-01-2014, 07:19 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Who makes the spacer? I know you said you ordered it from summit, but they should know at least what to get you rolling properly again, I'd like to get these for my 01 this weekend probably, but not with that headache
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 39 Old 07-01-2014, 08:01 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Leave that dealer now!
You don't go to the dealer for aftermarket levels or lifts...
I thought we talked about this, but it might have been someone else...
You'll need the largest adjustable camber kit made.
SPC Front Camber Kit Ford F250 F350 Super Duty | eBay
Here's what it looks like on my truck.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #9 of 39 Old 07-01-2014, 08:06 AM
dfuzz78's Avatar
Here is the kit installed...
Hopefully you have a metal spacer and not a plastic or poly...
The poly spacer is a whole other set of problems...
Denis "Lt. Sled"
dfuzz78 is offline
post #10 of 39 Old 07-01-2014, 08:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
What size tire can you run with that spacer up front now that we know where all the parts are
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
