Vibrations and driveshaft/ujoints - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-21-2014, 07:12 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I have a vibration coming from the back of my truck,it's been there for a while and I am trying narrow it down,not sure if it's ujoints ,drive shaft center bearing or the rear.Its more noticeable around 60-65 mph and tapers off so it seems .I notice it more when empty not nearly as much when towing.
How can I tell if the center drive shaft bearing /ujoints are going bad and would I be better off replacing those to eliminate or even doing prematinance since they are old?
The ujoints/center bearing are 10 years and have old never been replaced,but I know the center bearing has the rubber bushing that can go bad.I can move it up and down but it does not appear ripped.
Thanks....
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #2 of 4 Old 06-21-2014, 07:38 AM
ZMANN's Avatar
Quoted: 1343 Post(s)
i hate to say this but before I would spend much time diagnosing this I would take the driveshaft in and have it rebuilt unless you low mile ?
I just did the same ( my press broke 1 u joint in to the work so I said f this and went to a shop ) balanced and labor it was around 350-400 ( i supplied some parts so i don't have an exact $ amount ) mine was 7 years old and 100,000 miles
next question ( i read some of the 08 spring conversion ) is are you all stock except for that 1/2 " ? looks like it in the pic
another common area for vibration is tires how are those ?
We Miss you Ronnie
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
robertc68 (06-22-2014)
post #3 of 4 Old 06-21-2014, 07:43 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Originally Posted by ZMANN View Post
i hate to say this but before I would spend much time diagnoising this I would take the driveshaft in and have it rebuilt
next question ( i read some of the 08 spring conversion ) is are you all stock except for that ?
Yes my truck has nothing but oem parts ,the leafs are 2011.I used my old blocks.Also this vibration was there before I changed the leafs.
post #4 of 4 Old 06-22-2014, 05:06 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I am going to take your advice and get the local shop to replace and balance the shaft.
