04 2wd Dually Lift - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-17-2014, 07:12 PM Thread Starter
sixlitremac's Avatar
Garage
Question 04 2wd Dually Lift
I recently bought an 04 F350 2wd Dually, I haven't been able to locate a lift for the truck, looking for new re-arched rear springs 2-4" of lift and anything for the front. Does anyone have any ideas, greatly appreciated.
sixlitremac is offline
post #2 of 6 Old 06-17-2014, 07:51 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Seems as though fabtech sells one, but in the foot notes it states non Dually models what's the difference?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 06-17-2014, 08:07 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Aside from Dana 80 and sterling 10.50
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #4 of 6 Old 06-18-2014, 04:05 AM
F3502wd's Avatar
Feedback Score: 3 reviews
I have the same issue and here is what I found. You can run a 2" leveling kit (which Im going to do) with some 285 75 16's and call it a day. Or you can do a lift. There are two companies that make the lift. One is pro comp and the other is fabtech. The only difference is that who ever is installing the lift will have to get different ubolts for the rear. If you do go with the pro comp I suggest getting different shocks bc the ES9000's that it comes with are crap.
F3502wd is offline
post #5 of 6 Old 06-18-2014, 05:01 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I run a 265/75/16 now with no issue, the leveling kit comes with blocks? Could just find used Dually blocks from a 4x4 and call it a day and only get the front rite
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 6 Old 06-18-2014, 07:57 AM
F3502wd's Avatar
The front leveling kit is just a spacer. Now Im wondering if a can run a 35" tire lol. I hope the 285s arent to small
F3502wd is offline
