Newbie with a swr to drw conversion - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-09-2014, 08:33 AM Thread Starter
I have done some searching on the site but have not really found the answer to my question. I have 97 F250 7.3 5 speed that I want to make a DRW I have access to a 2001 F350 that has all the parts. Can i use this parts truck to make the swap.
Thanks Don......
Dconrad is offline
post #2 of 4 Old 06-09-2014, 01:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Yes but it's not an exact swap in your case being as the trucks have different bolt patterns, the obs also does not have rear disks stock, but many have used sd axles for axle swap conversions
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 06-09-2014, 05:19 PM Thread Starter
More ?
Kris,
Thanks for the reply .......... the 2001 has some nice aluminium wheels and pretty new tires all the way around can I not swap the complete setup ?
also what about the front hubs ?
Thanks Don
Dconrad is offline
post #4 of 4 Old 06-09-2014, 05:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If it's 4x4 and yours is 4x4 you need to swap the entire axles or get adaptors to run those wheels, the hubs will not swap directly on to your front axle because they are different axles (you may have a solid axle swap I'm not sure but the 86-97 Dana 60 is different then the 99-04 version)
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
