Not sure what ford to buy any information would be great - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-04-2014, 06:59 AM Thread Starter
Right now I have a 2007 dodge 6.7 and I want my next truck to be a ford agin I used to have 7.3 ford and then my last three trucks have been a 5.9 and two 6.7... I don't know much about the new fords but I'm looking for a 2008 and newer I just like the way they look.... Also I kind of like the f450 but I'm not sure. I tow a 36foot box trailer every day so I will be using the truck for what's its made for
Ronniepena is offline
post #2 of 7 Old 05-04-2014, 07:04 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
How heavy is the trailer would warrant wether you need a 450 or a 350, but the 6.7 and 6.4 fords a very powerful capable rigs, but are looking for a brand new rig or used one?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
Ronniepena (05-04-2014)
post #3 of 7 Old 05-04-2014, 07:57 AM Thread Starter
I'm looking for a used one under 100,000 miles.. I work for a house hold moving company so the trailer weight is always different and we don't stop at scales Much it's just when I'm crearious... But I have been 22,000
post #4 of 7 Old 05-04-2014, 09:53 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Well if your doing a lot of hauling your should just go the f450 then, I'm not sure on which is better but the newer it is the more amenities you can find, but the 6.4 and 6.7 can both be a powerhouse if you want and with a few mods both can be very reliable, you would have to check the 6.4 and 6.7 forums to pick your poison of what to look for when buying used and which is a better power plant
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 7 Old 05-09-2014, 05:44 AM
Sam Hain's Avatar
If I were you I'd stick with the cummins. Proven motor unlike the 6.4's that have radiator and hpfp issues. Along with valve train problems, cracked up pipes, cracked pistons etc. Not to mention the cluster the emissions stuff is if you have to leave it stock.
Sam Hain is offline
post #6 of 7 Old 05-26-2014, 05:50 AM
The Ford 6.4 had problems. . .if used you need to be sure that the problems have been fixed. Dodge has had very bad front end problems and currently has a recall for transmission trouble. Ford 6.7 is a good machine with newer models best.
2015 CC 6.7 4x4 LB
eco-rich is offline
post #7 of 7 Old 05-26-2014, 05:58 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
^^^^Agree. If my 6.0 goes boom today Ill be looking at the newer 6.7. LIVE ON 6.0 LIVE ON!!!!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
