My new to me 05 F350 CC KR - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-24-2014, 12:57 AM Thread Starter
mprc911's Avatar
Not new here, but my first post, and my first diesel.
Bought this about a month ago. Gave 16k for it. Interior is absolutely perfect, had 170k on it. Came with the 6 inch lift, unknown brand, also has 3 inch spring hats on the front for that perfect look. 315/70/17 Hankook ATM tires. 6.0 motor is completely stock, for now, (egr delete, new oil cooler, new K&N cold air all in the back seat). Has straight exhaust coming out infront of the dually , (stacks laying in my garage floor now). Hypertech programmer for now (it was free from a friend). Things already changed, the running boards to the 07 that are dropped down alittle more, clear cab lights, clear tails, clear side markers, all lights changed to smd, cree fogs, 6k HID heads. More to come.
So far have put 3,000 miles on it and its a beast of a truck, had all most 11,000 pounds on gooseneck, it and pulled at 70 mph like a dream. Egr is leaking coolant into the exhaust . Tearing into the topend next week. Wish me luck.
mprc911 is offline
post #2 of 12 Old 04-24-2014, 01:04 AM Thread Starter
mprc911's Avatar
Tried to make pic bigger but it won't let me for some reason. Probably user error.
mprc911 is offline
post #3 of 12 Old 04-24-2014, 06:50 PM
Nice looking truck!
Tjmaxx is offline
post #4 of 12 Old 04-25-2014, 03:14 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Great looking truck there
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 12 Old 05-02-2014, 10:30 PM Thread Starter
mprc911's Avatar
Wanted to show my recent haul, with all stock motor, and an EGR that is leaking into the exhaust. 80 food mobile home, 18k plus weight wise. Pulled like a champ.
mprc911 is offline
post #6 of 12 Old 05-02-2014, 10:39 PM
powerstrokecrzy's Avatar
Quoted: 250 Post(s)
If you mean egr cooler that is leaking into exhaust just how do you think that coolant is getting into the exhaust? That's right, through the engine. If it's leaking bad enough that you can easily notice it I'd go ahead and start gathering parts for a gasket/ stud job. Chances are you've already lifted the heads if you been towing that heavy.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #7 of 12 Old 05-02-2014, 10:39 PM Thread Starter
mprc911's Avatar
On vacation this week to do the following. Egr delete, new oil cooler, coolant cooler, 4 inch turbo back exhaust to 5 inch stacks. HID headlights.
Just put a Air aid filter in the stock air filter box, and cut open the inner plastic where the air box snorkel will suck in direct air from outside behind the grill, (just found that is called the Zoodad, done it to 3 different trucks. Never knew it had a name.)
mprc911 is offline
post #8 of 12 Old 05-02-2014, 10:44 PM Thread Starter
mprc911's Avatar
That was just my guess on where the coolant is going. Had a local Ford dealer check it. Didn't tell them about the coolant issue, and they stated the head gaskets were fine. But yes I can easily notice it, adding about a gallon of water a day . Its not leaking anywhere, and oil is nice and clean.
mprc911 is offline
post #9 of 12 Old 06-09-2014, 09:55 PM
Nice looking rig you got there.
2008 F350 King Ranch 6.4L , 6" RC lift, SCT Livewire Extreme
zpi28 is offline
post #10 of 12 Old 08-17-2014, 03:53 PM
emilio's Avatar
Quoted: 2 Post(s)
Nice truck.
My 2008 and I. Having fun in the snow
emilio is offline
