side marker light help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-13-2014, 03:09 PM Thread Starter
how does the front amber marker light mount to the dually flare? i bought a new lens from the dealer ship but im not sure how it mounts. theres no clips or anything to hold it in
lightn95 is offline
post #2 of 5 Old 04-13-2014, 05:37 PM
2000superduty's Avatar
Garage
I know on my 2000 there is a metal piece that goes on the back side of the flare and the light goes thru the front side and snaps into it. I have had to replace a few of them so far cause the metal clip on the backside rust's away and the light falls out.
00' F350 Lariet, CC, 4wd dually, 7.3L, diy intake, superchips, autometer gauges, 4" diamond eye.
2000superduty is offline
post #3 of 5 Old 04-14-2014, 06:06 AM
Sam Hain's Avatar
Sam Hain is offline
post #4 of 5 Old 04-15-2014, 03:10 PM Thread Starter
kinda, is there a retainer clip that goes inside the flare? or does the rubber/felt piece go inside and that holds the lens on?
lightn95 is offline
post #5 of 5 Old 04-15-2014, 03:50 PM
portcity_gt's Avatar
Quoted: 1282 Post(s)
The flat steel part goes inside the fender, you will need to remove the black splash shield to easily get to it. There are some wedge shaped tabs on the plastic light that snap into the steel sandwiching the fender.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
