Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 12-05-2008, 11:07 PM
gp49 gp49 is offline
What is the difference...FRONT vs REAR
I have a 2002 DRW 7.3 CC 4x4. What is the difference in factory aluminum rims between the front and rear. I noticed that they have stamped numbers on them and the fronts are stamped "FRONT" and "REAR" on the rears. I'm getting ready to rotate the tires and I'm trying to find out if I need to dissmount the tires in order to do so................
Thanks in advance,
Mark
Old 12-05-2008, 11:20 PM
justinbaldwin69 justinbaldwin69 is offline
Thanks in advance,
Mark
you should be able to rotate the front with the outer dools
Old 12-07-2008, 11:20 PM
portcity_gt portcity_gt is offline
poop comes out of one.
Old 06-07-2009, 07:08 AM
quequeg37 quequeg37 is offline
go side to side
i don't think you'll be able to swap front with outer dualls. they should be different rims. you can swap across (side to side) on the front and same on rear. if your rims are alum. your rear inner tires are probably steel. if you want to do it by the book, the tires have to be broken off the rims and then remounted and balanced to be done properly.
Old 06-07-2009, 08:15 AM
460+ 460+ is offline
The front rims are polished on the outside not the inside so if you rotate the front to the rear it will be dirty showing out. Same goes for the rear.
Old 07-08-2009, 03:20 PM
SpecMiataHauler SpecMiataHauler is offline
I did it with my stock rims on my '06, front to outer back and besides them looking a little dingy they were fine.
